Calculating Speed of a motion of a Circular Object
To calculate the speed of a ball in a conical pendulum, the radius of the circular motion is determined using the formula R = L * sin(θ), where L is the string length and θ is the angle. Given L = 1.70 m and θ = 37.0°, the radius is calculated as approximately 1.02 m. The circumference of the circular path is then found using the formula C = 2πR, resulting in a value around 6.3 m. The speed is calculated by dividing the circumference by the time for one revolution, yielding a speed of approximately 2.7 m/s. Various calculations provided by participants indicate slight variations in results, but the method remains consistent.
Jordash
A conical pendulum is made of a ball on the end of a string, moving in circular motion as represented in the figure below. The length L of the string is 1.70 m, the angle θ is 37.0o, and the ball completes one revolution every 2.30 s.
Calculate the speed of the ball, by first deriving a symbolic equation and then inserting the
numbers.
I sort of know how to do this problem without the degrees.
I can't see the picture, but I presume that it is rotating in a horizontal plane.
First of all you know that the ball is describing a circle that has a radius of L*Sin37°.
You know the time to complete a revolution ...
Alright, here is what I got
R=L*sin(37)
R=1
Diameter=2
Circumference=pi(2)
Circumference=6.3
Speed=Distance Traveled/Time
Speed=6.3m/2.3s
= 2.7m/s
Is that right?
Looks about right.
I get 1.02 m
and 6.41 and 2.79.
