Calculating Spring Stretch on a Ramp with Varying Acceleration and Friction
  • Thread starter Thread starter Tim Wellens
    Block Ramp Spring
The discussion revolves around a physics problem involving a block on a ramp with a spring, focusing on calculating the stretch of the spring under different conditions, including acceleration and friction. The subject area includes mechanics, specifically forces, spring dynamics, and frictional effects.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to calculate the spring stretch using force equations and questions the derivation of the gravitational force component along the ramp. They express uncertainty about how acceleration influences the spring's behavior in the second part of the problem.
  • Some participants provide geometric reasoning to clarify the relationship between gravitational forces and the spring force, suggesting a triangle representation to visualize the forces involved.
  • There are inquiries about the appropriateness of the approach taken for part b, with participants suggesting the use of free body diagrams to analyze the forces acting on the block.
The discussion is active, with participants providing clarifications and exploring different interpretations of the problem. Some guidance has been offered regarding the geometric representation of forces, and there is an ongoing exploration of how to approach the second part of the problem involving acceleration.
Participants are working under the assumption of a frictionless scenario for the initial parts of the problem, with later parts introducing coefficients of friction. The original poster is also holding the spring stationary, which adds complexity to the analysis.
Tim Wellens
1. Homework Statement
We are dealing with a block of 20 kg mass on a ramp that is at an angle of 30 degrees. The spring constant given is 500 N/m.
Picture- https://flic.kr/p/A3aCsM
The only difference is that that we are supposed to be holding the spring stationary, it isn't attached to a wall.
Assume frictionless for a and b.The questions wants to know a) how far the spring will stretch at rest
b)You pull so the block is accelerating at 4m/s^2 up the ramp. How far does the spring stretch?
c)Now you are to assume you are on a ramp with the following coefficients of friction us=0.3 and uk= 0.2. If you are initially holding the free end of the spring and you pull the spring so that the block is accelerating at 4m/s up the ramp, how far is the spring stretched?
Fspring=kx
a) I used F=mgsinΘ to find that the force is 98 N, then I used F=kx to get x=F/k= 98N/500N/m=0.196m
I think this is how to do it, but I was wondering if someone could help me understand where F=mgsinΘ came from? Is the force of the spring equal to the x component of the weight because the block is attached at rest?
b)
I am at a full loss of how to start the second part. I think the question means that since we are holding the free end of the spring, we just pull it back. But I'm not sure how acceleration plays into any of the equations for the spring unless since.. Fspring=mgsinΘ=kx and ∑Fx=mgsinΘ=ma because we pull on it, we can set ma=kx, and solve for x? That's the only thing I can think to do.
For a) In order to determine the force on the spring, you have to determine how much of the vertical gravity force is directly opposite to the direction that you are pulling the string. To help yourself understand first, put a dot in the center of the block and second, draw a short vertical line downward (this is the direction of the force of gravity), next, from the dot, draw another line parallel to the ramp going down the ramp; and, finally starting at the bottom of your first vertical line, draw a line upward perpendicular to the slope of the ramp until it intersects your line going parallel with the ramp. By now you will have formed a 30 degree right triangle with it hypotenuse being the direction of the force of gravity and the short line being the amount of the gravity force that is directly away from your spring and the length of that short line is = F gravity x sin 30 degrees. Additionally, the other leg of the triangle represents the amount of gravity that is acting to create the friction of the block and it = F gravity x cos 30 degrees.
Does that help?
Yes, that helps clear up the reason behind part A a lot, thank you! :smile:
For part b, was I totally off on how to figure out the stretch of the spring if the acceleration is 4 m/s^2?
Just draw the usual FBD. What are the forces, what is the net force, etc?
  • · Replies 33 ·
