Calculating starting/tractive force
  • Thread starter Thread starter snwright
    Force
To calculate the force needed to overcome inertia for a 1500 lb sliding door, the initial calculation of 93.74 lbs is based on acceleration without considering friction. To include friction, the resistance force is determined by multiplying the weight of the door by the coefficient of friction, which requires adjusting for the four wheels to ensure even load distribution. The correct formula incorporates both friction and acceleration: F = m(0.02g + a), where g is 9.81 m/s² and m is the mass in kg. After calculations, the total force required amounts to 176 N or approximately 40 lbs. Understanding these dynamics is crucial for accurate force calculations in similar applications.
snwright
Hey all-
First post here!
I need to calculate the force required to overcome inertia of a 1500lb object. It's a sliding door, which rolls on 4 identical wheels, each with a coefficient of friction of .02. I'd like to make it accelerate to .25m/s over a period of 4 seconds.
I think what I need OMITTING FRICTION is: F=Ma = 6672 N * .0625m/s2 = 417 N = 93.74 lbs. Is that accurate? How do I include the resistance due to friction?
thanks!
Spencer
Resistance due to friction is weight of door times coefficient of friction. You need that much additional force. Be careful about how you consider the four wheels.
How should I be considering them? The load should be distributed pretty evenly across all four wheels. I was thinking that it would be a wash, and that the accumulated drag would be .02.
You need to add all the resistance forces to the inertia. The force needed would be:
F = 0.02mg + ma = m (0.02g + a)
g is 9.81 m/s² and the SI unit for m is kg not N (So 1500 lb is 680 kg). F = 176 N = 40 lb.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
