Calculating the Deceleration of a Car in an Emergency Stop
  • Thread starter Thread starter Kujanator
    Car Deceleration
The discussion focuses on calculating the deceleration of a car during an emergency stop, given its mass of 450 kg and an initial speed of 70 MPH (31.3 m/s) with a braking distance of 75 m. The user initially struggled with the equations of motion but ultimately calculated the deceleration to be approximately -6.53 m/s². A typo was noted in the user's initial equation, but the overall method was validated. The conversation then shifted to how the stopping distance changes when the car's mass is doubled, leading to a recalculated stopping distance of 135 meters. The importance of understanding the relationship between force, mass, and acceleration was emphasized for accurate calculations.
Kujanator
The braking distance is the distance the car travels while decelerating once the brakes have been applied. A car of mass 450kg is traveling at a speed of 70MPH (31.3ms-1) when the driver makes an emergency stop.
Calculate the deceleration of the car (Assume a uniform deceleration)
We're also told that at 70mph/31.3ms-1 that the breaking distance is 75 m.
I did initially try to do this using the equations of motion but that gave me a huge answer, and didn't take into account the mass of the car so I didn't think it was right.
Any help is hugely appreciated!
You should show your attempt, even if it has an error or two. That way we will know how to help.
Ok, this is what I did.
S=75
U=31.3
V=0
A=?
T=?
s=u²+2as
0=31.3²+2*a*75
0=979.69+150a
-979.69/150=a
a=-6.53 ms-2
Which looking back doesn't look too bad, when I did it first time I think I accidentally must have typed the wrong numbers into my calculator because I got -1000ms-2. I'm just thinking I did it wrong because I didn't use the mass.
S=75
U=31.3
V=0
A=?
T=?
s=u²+2as
0=31.3²+2*a*75
0=979.69+150a
-979.69/150=a
a=-6.53 ms-2
Looks good.
One small nit though, in your first equation you put "s" on the left where you meant to put "V2". Clearly a typo, since you correctly substituted the value of V2 in your next line. So overall, well done.
There's just one other part:
The car is then filled with passengers so that its mass is doubled. Calculate its stopping distance when traveling at 70MPH. Assume the force calculated in b(ii) remains constant.
I calculated the force as:
F=ma
F=450*6.53= 2938.5N
How do I go about doing this is it:
2938.5 = 900 * a
2938.5/900 = 3.625
So:
v²=u²+2as
0=31.3²+2*3.625*s
-979.69/7.25=s
s=135 metres.
Thanks again!
Check your value for the new acceleration. Looks like a finger problem. Otherwise you're method works okay.
You could skip the force calculation if you realize that since F = MA, then A = F/M. Therefore if you double M you must halve A.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
