Calculating the force of friction on an object
A 40.0-kg object is being pulled with a 200 N force at a 30° angle, and the coefficient of static friction is 0.40. The calculated force of friction was initially thought to be 197 N, but the correct answer is 173 N. The confusion arises from misinterpreting the type of friction involved, as the problem includes red herrings. Understanding the dynamics of the situation is crucial for accurate calculations.
purplecows
A 40.0-kg object is being pulled along a horizontal surface by means of a rope that exerts a force of 200 N at an angle of 30° below the horizontal. The coefficient of static friction between the object and the surface is 0.40. The force of friction on the object is:
A) 197 N
B) 173 N
C) 392 N
D) 157 N
µ_s = F_s/ F_n
So I got 197 N, which was A. However, the answer was B on the answer sheet. What have I done wrong?
I think you mean 'coefficient of dynamic friction'.
Your drawing is hard to decipher.
hi purplecows! welcome to pf! :wink:
so do i :smile:
(are you ok on your other thread?)
The answer is B and it's correct.
There are a lot of red herrings in this problem! I fell for the "static friction" coefficient myself.
The force is already given, so things like friction coefficients and mass are irrelevant.
Likes 1 person
