Calculating the Speed of a Dropped Rock on Mars
  • Thread starter Thread starter kmiller
    Mars Rock
To calculate the speed of a rock dropped from a height of 0.90 m on Mars, the relevant equation is Vf^2 = Vo^2 + 2ad, where Vf is the final speed, Vo is the initial speed (0 in this case), a is the acceleration (3.73 m/s²), and d is the distance (0.90 m). The initial attempt used incorrect calculations, leading to confusion about the correct method. Including units in calculations is emphasized for clarity. The correct final speed can be determined using the appropriate equation, ensuring accurate results.
kmiller
An astronaut on Mars drops a rock straight downward from a height of 0.90 m. If the acceleration of gravity on Mars is 3.73 m/s2, what is the speed of the rock when it lands?
find m/s
.90m/3.73m/s2=.2413
squareroot .2413=.491
.90m+1/2(3.73m/s2)(.491)
=1.816m/s
it was wrong what equation am i suppose to use?
There is an easier equation that you can use : Vf^2 = Vo^2 + 2ad.
Also, just a suggestion, it's a lot easier to help you when you put units on your answers.
ill remember that
I got the right answer I think I am just having a hard time with what equations I have to use.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
