Calculating transition rate between nljm resolved states
Khashishi
I know how to calculate transition rates between nl resolved states in a hydrogen-like atom, but I don't know how to calculate transition rates between nljm states.
I know that dipole transition rate is
\frac{32}{3}\frac{\pi^3 \alpha c}{\lambda^3}\left<\psi_1|\mathbf{d}|\psi_2\right>
The matrix elements on the right can be separated into a radial integral and an angular part. The radial part is
\int R_{nl} R_{n'l'} r^3\,\mathrm{d}r
If we pretend that spin doesn't exit, the angular part goes something like
\iint {Y_l^m}^{*} Y_1^{0,\pm 1} Y_{l'}^{m'} \sin(\theta) \,d\theta\,d\phi
I can solve this using Clebsch Gordan coefficients, and it seems to give the right answer. But, I have no idea what to do when I add in spin angular momentum. It seems this integral doesn't make sense if I replace l with with 1/2 integer j.
I tried some various things, and I ended up with something that gave the right answer in some cases but not in others. I'm always off by some multiple of some rational. I know it has to do with degeneracy and angular momentum addition, but I can't figure it out. Any resources?
When including spin, ##j## replaces ##l## in the angular part.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
