Calculating velocities with only acceleration and time
  • Thread starter Thread starter noelani
    Acceleration Time
To calculate the initial and final velocity of a ball thrown upward and caught at the same level, the relevant equations are Vf = Vi + at and delta x = Vi*t + (0.5)(t^2). Given the acceleration due to gravity is -9.8 m/s² and the time is 2.12 seconds, the initial and final velocities can be determined. Since the ball is caught at the same horizontal level, the initial and final velocities are equal in magnitude but opposite in direction. The discussion emphasizes the need to identify the correct equations and understand the relationship between velocity, acceleration, and time.
noelani
This was a basic physics experiment. A ball was thrown upward and then caught. Calculate initial and final velocity given: acceleration= -9.8m/s^2 (gravity); time= 2.12sec
delta x=Vi*t+(.5)(t)^2
Vf=Vi+at
I actually don't know where to begin. I don't know an equation for velocity that doesn't require displacement (which I also need to find).
if it's caught at the same horizontal level, then vi=vf [note the direction of each, one is + and the other is -]
solve!
ps. welcome to PF :)
solve!
Thanks for the help. So how would I figure out which equation to use?
