Calculating Water Flow Using a Venturi Meter
2 replies · 3K views · last reply
HethensEnd25
A 4 inch to 1 inch diameter venturi meter is used to measure water flow and it
has a mercury manometer deflection of 1 inch. What is the discharge
through the four inch diameter pipe?
Bernoulli Equation, manometer formula
Thus far my attempt at a solution is using the Reynolds Transport Theorem. I know that for a steady flow process that there will be no change in volume for the control volume. Thus that term will be zero. So now I am left with
∫ρV*dA
I have two diameters given and I know that it is a in-compressible fluid. So my flow in must equal my flow out. I am confused however upon the given information regarding the mercury deflection. Am I to use that deflection to give myself a pressure? Or is that a piece of information that is nonessential in approaching this problem?
Best Regards,
D
The pressure differential is absolutely essential information.
You can use Bernoulli's equation and the continuity equation to solve for flow rate.
Thank you for your insight. I have solved the problem. I will post my answer once I am home to double check.
Best Regards,
D
