Calculation of inertia resistance in my geometry
The discussion focuses on the calculation of inertia resistance in a rotational system with regular geometry. The key equations mentioned are I * α for torque and I * ω² for energy, highlighting their distinct applications. Angular momentum is represented by Iω, while the relationship between torque and moment of inertia is clarified through the equation d/dt(Iω) = Iα + (dI/dt)ω. It is emphasized that understanding these fundamental concepts is crucial for accurate calculations. Proper application of these equations is essential for analyzing rotational dynamics effectively.
Analysis
Dear all,
I have bit vague about calculation of inertia resistance in my geometry.i have rotational system of regular geometry,i have calculated the "I"value .
which equation i have to use I * alpha or I *w(omega^2),or they both in same...
In some calculations later equation is used...
Prakash
Hi Prakash! :smile:
(have an alpha: α and an omega: ω and try using the X2 tag just above the Reply box :wink:)
Learn your moment of inertia basics …
Iω is angular momentum, 1/2 I ω2 is energy,
and d/dt(Iω) = Iα + (dI/dt)ω is torque (so if I is constant, then Iα is torque). :smile:
The basic equivalence to inertia is mass, like in p (momentum)= mv. In rotational systems, it would be the moment of inertia, like mb2 for a point mass m at the end of a massless rod of length b.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
