Calculation of Workdone and Energy Answer for First and Second Question
  • Thread starter Thread starter icystrike
    Energy
The discussion revolves around the calculation of work done and energy in two separate questions, focusing on the application of physics principles related to forces, energy, and work. The subject area includes concepts from mechanics and energy calculations.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants discuss various calculations for work and energy, questioning the relevance of certain information provided in the problems. There is an exploration of the assumptions regarding forces acting on the objects and the clarity of the questions posed.
Some participants have provided their interpretations of the questions and calculations, while others have raised concerns about the wording and completeness of the information given. There is an ongoing examination of the assumptions made in the calculations, particularly regarding the forces involved and the conditions under which work is done.
Participants note that the lack of certain information, such as the friction coefficient and time periods, affects the ability to fully deduce energy consumed in the problems. The wording of the questions is also highlighted as potentially misleading.
icystrike
Answer stated is D
Answer stated is D
My attempt at the solution:
For the first question,
the calculations are as follow:
A. P=I2R = 42×12 = 192 J/s -- Missing information
B. Energy = 1/2 mv2 = 15×9= 135J
C. Energy = mgh = 10×10×1 = 100J
D. Work done = 0J ; moving against zero friction.
My answer will therefore B for the first question.
For the second question,
Work done = Ffric × d = 70N×4m = 280J
The information with regards to the mass of the object is irrelevant since the friction coefficient is not stated and the frictional force has been stated in the problem.
My answer is A for the second question.
I like your answers. It appears that the wrong answer D in each case arises from the mistaken view that work must be done against the force of gravity and that this work is equal to the weight times the distance moved (even though the weight force is perpendicular to the displacement).
The wording of the questions is not very good. In option D for #14 and in #25, there is no information about whether or not the speed of the object remains constant . In #25 the phrase "energy exerted" is a bit odd. We don't normally think of "exerting" energy.
Thanks for your prompt reply and assurance that my conceptual knowledge is not at risk. May also I get you to acknowledge if the information provided for #14 (A) is incomplete to deduce the energy consumed.
You are completely right. You would also need to be given a time period in order to get energy in #14 (A).
I agree. As written the answers are B and A. Very badly worded questions.
  • · Replies 60 ·
  • · Replies 33 ·
  • · Replies 23 ·
