The discussion revolves around the use of a psychometric chart to determine the relative humidity (RH) of air in a cooling process. Participants explore whether the chart can provide the necessary information given the temperatures involved and the conditions under which moisture begins to condense.
- Homework-related
- Technical explanation
- One participant questions the ability to use the psychometric chart for temperatures above 30°C, noting that the wet bulb line does not extend to 40°C.
- Another participant suggests that the saturation vapor pressure of water at 40°C and 45°C is relevant for determining the partial pressure of water vapor in the air.
- There is a clarification on the definition of relative humidity, described as the ratio of partial pressure to saturation partial pressure at a given temperature, multiplied by 100.
- One participant expresses a desire to confirm the correct use of the psychometric chart rather than seeking a complete solution to the problem.
Participants do not reach a consensus on the use of the psychometric chart for this problem, with some expressing uncertainty about its applicability to the given temperatures.
The discussion highlights limitations in the psychometric chart's range and the need for saturation vapor pressure values, which are not provided in the thread.
