Can I operate a 230V, 50 Hz, 500 W german oscillating saw
  • Thread starter Thread starter miforensic
    German Oscillating
Operating a 230V, 50 Hz, 500 W German oscillating saw in the US is feasible with a 1000 W step-up voltage converter, which converts 110 V, 60 Hz electricity to the required specifications. Concerns about overheating are minimal, especially since the saw is only used for short durations weekly. The converter should adequately support the saw's power needs, and it may even run slightly faster due to the frequency difference. Confirmation from the manufacturer indicates compatibility, suggesting the tool should function properly. Checking the service manual for motor type can provide further assurance on its operation.
miforensic
Can I operate a 230V, 50 Hz, 500 W German oscillating saw in the US? I purchased for it a 1000 W step-up voltage converter in order to convert to 110 V, 60 Hz electricity used here in US. I am worried that 1000 W may not be enough. I am using the unit for 3-4 minutes at a time, once a week.
Those beautiful "Feins." Never had mine get hot, but it's made for U.S. mains. Kilowatt converter should keep it happy.
Thank you, the unit is an "Elektrik Power" cast saw. I was worried about the switch from the German 230 V, 50 Hz to our 110 V 60 Hz and the overheating of the tool.
Wait a minute --- the converter does take 110 V 60 Hz and put out the 230 V 50 Hz?
The 1000 W voltage converter is a step-up/step-down unit and I assume that being operated here in US will take 110 V and 60 Hz. The German tool is meant to operate under 230 V, 50 Hz and 500 W. The manufacturer just email me that it should work.
Might run a little faster this side of the pond, 60 vs. 50 Hz. Thought I'd double-check you.
If you can find the service manual - you may see the motor connections and determine what type it is using. If it is a universal motor you will probably be OK.
