Solving Carnot Heat Problem: 1637.8BTU Answered
  • Thread starter Thread starter Windseaker
    Carnot Heat
The discussion centers on calculating the heat extracted from a heat source by a heat engine connected to a 300-watt motor, operating at 40% efficiency for 4 hours. The calculations show that the total heat extracted is 1637.8 BTU, with the engine utilizing more heat energy than the work it produces. There is a debate about the use of BTU versus joules for heat measurement, with an emphasis on BTU being more common in residential contexts in the US. The time factor of 4 hours is confirmed to be relevant in the calculations. Overall, the focus is on understanding the efficiency and energy output of the heat engine.
Windseaker
Problem: A heat engine is connected to a 300watt motor. If we power the motor for 4hrs and heat engine is 40% efficient,how much heat is extracted from heat source in?
Given: Q= heat QC=waste heat QH=W+QC and Power=E/t or Work/t
This is a diagram equation of heat.
QH-----l----->QC
l
l
V
300w
300W(3.412btu/1W)= 1023.6btu (4hr) = 4094.4 btuh
----- 4094.4btu(40%)=1637.8btuh
The engine uses more heat energy than the work it yields: the work is 40 % of the heat: W=0.4*Q.
Do you really use btu units for heat instead of joule?
ehild
So, are you saying that time is not used here (4hrs)? its just the starting heat loss.
yes btu, this is more about residential usage in US.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
