Calculating Kinetic Energy for Colliding Carts
  • Thread starter Thread starter crimsondarkn
    Cart Collision
In a collision scenario involving a 2.4 kg dynamics cart moving at 1.5 m/s and a stationary 3.6 kg cart, the velocity of both carts at minimum separation is determined to be 0.6 m/s [W]. The conservation of momentum principle is applied, leading to the calculation of the center of mass speed and the subsequent velocities of the carts. The discussion also addresses the change in total kinetic energy during the collision, with initial and final kinetic energies calculated to show a loss of energy. The final kinetic energy difference is noted as -1.6 J, indicating energy was lost in the collision. The calculations emphasize the importance of correctly applying the kinetic energy formula without simplifying incorrectly.
crimsondarkn
A 2.4 kg dynamics cart with a linear elastic spring attached to its front end is moving at 1.5 m/s [W] when it collides head on with a stationary 3.6 kg cart.
What is the velocity of each cart at minimum separation?
The answer is 0.6 m/s [W]
Can anyone show me the steps?
What is the velocity of each cart at minimum separation?The answer is 0.6 m/s [W]
There is a very easy way to do this. Since there are no external forces, the total momentum the system does not change. What is the speed of the centre of mass? (What is the speed of the observer who sees the two cars colliding with equal and opposite momenta?)
What is the relationship between the speed of the centre of mass and the speeds relative to the centre of mass of the two cars at minimum separation?
AM
Oh I got it, thanks!
This is what I did..
m1v1+m2v2=m1v'1+m2v'2
m2v2 becomes zero since its stationary
m1v1=v'(m1+m2)
-3.6=v'(6)
v'=-3.6/6
v'= -0.6 m/s ---> 0.6m/s[W]
I didn't know it was completely elastic collision, that's why I was stuck.
I'm stuck on part c now...
Calculus the change in total kinetic energy of the system at minimum separation. Here's my work
v'=-0.6m/s
1/2m1v1^2 + 1/2m2v2^2 = 1/2m1v1'^2+1/2m2v2'^2
cross out all the 1/2s and also v2 becomes zero
m1v1^2 = m1v1'^2 + m2v2'^2
(2.4)(-1.5)^2 = (2.4)(0.6)^2 + (3.6)(0.6)^2
5.4 = 0.864 + 1.296
5.4 = 2.16
5.4-2.16 = 3.24 J
And this is where I'm stuck...
The answer at the back is -1.6 J
Don't write this as an equation (since they are not equal!) and don't cross anything out. You have the speeds and the masses, so just calculate the initial and final KEs by plugging into the KE formula. Then compare KEi to KEf. (By "final" I mean at the point of minimum separation.)
