Centre of mass problem; Non uniform rod with ball weights
The discussion revolves around a physics problem involving a non-uniform rod and the calculation of its center of mass. The rod has a linear mass density that varies along its length, and the center of mass has been determined to be at 4/9M (approximately 0.44444m) from the heavier end. The challenge lies in determining how many uniform metal balls need to be added to the lighter end to tip the rod over. The original approach involved balancing the center of mass but did not account for the positioning of the balls effectively. Participants are seeking strategies to solve this balancing problem, emphasizing the need for a clearer method to incorporate the masses and positions of the added weights.
Conesdome
A non uniform rod of length L=1m and linear mass density:
λ(x)=λo(1-(x/2L))
with λo=1Kg/m. It is supported at it's midpoint and initially tips over so that it's left end lies on the ground.
Part a: Find the position of the centre of mass along the rod when it is in it's horizontal position.
Part b: One begins to fix small uniform metal balls of radius r=1cm and mass m=50g to the lighter end of the unbalanced rod. Starting from the end and moving inwards with each ball touching the next. How many balls does it take to tip the rod over?
That is the bones of the question. Here is a link to the actual question more clearly outlined with diagrams.
http://i.imgur.com/Hnr3z.png
M=∫λ(x)dx
X(centre of mass position)= 1/m∫xλ(x)dx
I have already solved part a. The mass of the rod is 0.75Kg and the position of the centre of mass (Xcm) is 4/9M (0.44444m).
I have tried for hours today and yesterday to solve part b but not had any luck. My original idea was to make the centre of mass L/2 (0.5m) and then solve for the mass. Then I got the difference in the masses and tried to find how many metal balls would equal that mass. This didn't feel right as the size and position of the balls of the rod are not been taken into account. I don't know how I am meant to approach this question at all. Is it a case of balancing masses, of balancing the forces on either side or perhaps splitting the rod into segments that make it easier to deal with? Any help/suggestions would be greatly appreciated.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
