Centripetal acceleration changing radians/s into rpm's
To achieve a centripetal acceleration of 100g for a copper sleeve with inner and outer radii of 2.10 cm and 2.20 cm, the required angular speed can be calculated using the formula ac = rω². The calculation leads to ω = √(100g / 0.021 m), which simplifies to approximately 216 radians per second. Converting this to revolutions per minute involves using the conversion factor of 1 rev per 2π radians and multiplying by 60 seconds per minute, resulting in about 2060 rpm. The user is seeking clarification on using a TI-83 calculator for these calculations and has noted a potential error in their initial approach. The discussion emphasizes the importance of showing work in detail rather than just providing an answer.
mhuffman
Centrifugal castings- a copper sleeve of inner radius 2.10 cm and outer radius 2.20 cm is to be cast. To eliminate bubbles and give high structural integrity, the centripetal acceleration of each bit of metal should be 100g. What rate of rotation is required? State answer in revolutions per minute.
r=radius, ac=centripetal acceleration, ω=angular speed, g=gravity.
What I have right now is: ac=rω2, so every particle must undergo 100g of acceleration giving ac=100g or rω2=100g reduced to;
ω=√100(9.8m/s)/2.10 x 10-2m
the conversion factor will be the answer in rads/s (1rev/2π)(60s/1min)
My problem is converting this into radians per second then into rpm's. I am not looking for the answwer per say, but how to put this into my Ti-83 plus and doing the math. I also need to be able to show my work in long hand and just throwing out an answer will not work. I tried using the r from the angle setting and using both radians and degree mode, I looked in the manual but it use of no use. I am sure I am just overlooking something simple, any help would be great.
Thanks and have a great day.
Oops, I obviously made a mental/keystroke error. I believe I got it right, I have:
ω=√100g/2.10 x 10-2m
ω=216 rads/s=rpm=216rads/s(1rev/2∏rad)(60.0s/1min)=216(30/∏) leaving rpm's
216rads/s=2.06 x 103 rev/min
If you happen to see any mistakes, feel free to comment,
Thanks and have a great day,
m
