Changing the order of integration
  • Thread starter Thread starter a1010711
    Integration
a1010711
change the order of integration in the follwing double integral:
intgral [0,a] integral [0,sqrt(2ay-y^2)] f(x,y) dx dy
if x= sqrt(2ay-y^2),, do i solve for y or something,,ive used the computer to graph it but that didnt help me.
Then presumably you see, from the graph, that the region of integration is a semi-circle with center at (0,a), radius a and extending to the right of the y-axis.
If you had not graphed it you could still get that by noting that x= \sqrt{2ay- y^2} can be expanded, by squaring both sides, to x^2= 2ay- y^2 or x^2+ y^2- 2a= 0. Completing the square, x^2+ (y- a)^2= a^2 which is a circle of radius a, center at (x, 0). Of course the square root is never negative so that is just the semi-circle with x non-negative.
However you determine region, to reverse the order of integration, so that you are integrating with respect to y first, and then with respect to x, the limits of integration on x must be numbers so they should be the smallest and largest possible values of x in that semi-circle. To get the limits of integration for y, draw a vertical linel, representing a particular value of x. The limits of integration for y are the lowest and highest value of y on that line- the values at the endpoints (and, of course, they depend on x).
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
