Charging/Discharging Capacitor & Magnetic Field
The discussion revolves around a physics problem involving a circuit with a capacitor placed in an increasing magnetic field. The initial current in the circuit is determined to be 0.4 A, flowing counterclockwise. To find the time it takes for the capacitor to charge to 25% of its final charge, the equation Q(t)=Qf(1-e^(-t/rc) is applied, but the user struggles with the calculations. The final charge (Qf) is calculated using Q=VC, resulting in 9.5e-5 C, but the user encounters difficulties in solving for time. Clarifications are provided regarding the need to multiply by the final charge when calculating the 25% threshold.
longcatislong
The magnetic field in the region shown below is increasing by 5 T/s. The circuit shown (with R=25 , C=95 µF, dimensions 1 m by 2 m) is inserted into the region as shown. The capacitor is initially uncharged.
See Diagram: http://www.webassign.net/userimages/23-31.gif?db=v4net&id=50305
a.) What is the current in the circuit at the moment the circuit is put in the B field?
.4 A
direction: counterclockwise
b) How long will it take the capacitor to charge to 25% of its final charge?
c) How much charge will the capacitor hold after a long time (assuming this magnetic field rate increase is maintained)?
Q(t)=Qf(1-e^t/rc)
Q=VC
I'm using Q(t)=Qf(1-e^t/rc) to find time.
First, I found Qf by using Q=VC. I know that V=IR so, Q=IRC, =(.4)(25)(9.5e-6)
Qf=9.5e-5
Then, I used Q(t)=Qf(1-e^t/rc)
.25=9.5e-5(1-e^-t/[(9.5e-5*25)]
I'm not getting a real or correct answer for this.
Your assistance, any help you could offer is much appreciated. THANK YOU!
I think you numbers are correct but when the charge is 25% that means 25% x final charge.
I think you have just forgotten to multiply by the final charge??
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
