Check my static equilibrium diagrams
The discussion revolves around the creation of static equilibrium diagrams for a physics lab report. The user seeks clarification on whether to represent individual force vectors for each weight attached to a meter stick, as their professor indicated an error in their analysis. Responses suggest that while the overall format of the diagrams may be acceptable, adding individual force vectors is necessary for clarity. Additionally, there is a recommendation to include a torque vector in one of the diagrams and to represent the mass and location of the ruler separately to accurately depict equilibrium conditions. Accurate representation of forces and torques is essential for demonstrating static equilibrium effectively.
bananan
Hi physics fans,
I've made four diagrams for inclusion in a physics lab report. They depict situations in which a meter stick is in static equilibrium (no net torque, no net force). My professor mentioned to me that my analysis of the forces on the stick is not correct, but was not more specific than that.
Can you take a look at my diagrams and help me figure out where my error is? Do I need to show a force vector pointing towards the Earth for each weight attached to the meter stick? I thought it was correct to consolidate all of them into one (since the center of mass of the system has to be over the pivot point for static equilibrium to exist) Links to my diagrams are below:
http://img325.imageshack.us/img325/9105/physlab8apparatus1sn5.th.png
http://img261.imageshack.us/img261/3782/physlab8apparatus2fk8.th.png
To me, the diagrams are confusing for the reason you stated.
"Do I need to show a force vector pointing towards the Earth for each weight attached to the meter stick?"
So, yes. The diagrams look easy on the eyes, but is the professor looking for more of a plain free body diagram?
Maybe add to the pivot point that sum of the moments about the pivot point is equal to zero. EMpivot=0
Well, the trouble with plain free body diagrams is that they don't show both torques and forces. I think the professor is ok with the format of the diagrams, but your advice about adding individual force vectors to the weights is well taken.
One other question: in diagram four, does there need to be a torque vector pointing "out of the page" on the left side of the pivot point? I believe I need to add this, since (W-left side of ruler) * (moment arm from pivot to left side of ruler center of mass) is > 0.
I would also show the mass and location of the ruler independently from the weights because a condition of equilibium cannot be seen as depicted.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
