Engineering Circuit Complex Numbers question help
The discussion centers on determining equivalent resistance and capacitance values for a parallel RC circuit that matches the impedance of a series circuit consisting of a 280 Ohm resistor and a 0.3 uF capacitor at 700Hz. The key point is that the impedance equivalence must hold at a specific frequency. The user successfully calculated the parallel resistance as 2.331 kΩ and the parallel capacitance as 264 nF using complex numbers and relevant formulas. The importance of Thevenin's theorem in this context was highlighted. Ultimately, the user clarified that this was a practice question, not homework.
ckeller
Hey there, I have a question to answer and I'm unsure what exactly it is asking for, could anyone shine some light as to what this means? Is it two RC circuits in parallel??
"A circuit consisting of a 280 Ohm resistor in series with a 0.3 uF capacitor is connected to a supply operating at a frequency of 700Hz.
Use complex numbers to determine the values of the resistance "R" and capacitance "C" that when connected in parallel will represent the same value of impedance to the supply"
Google Thevenin's theorem.
If this is homework, it shouldn't really be in this forum. :-)
Hey thanks for your reply, I will look into that.
It's not homework, just a practice question I was unsure of :)
I think in other words..how would you get the same Impedance changing from a series RC circuit to a parallel RC circuit?
There will be a combination of RC in parallel that has exactly the same impedance as a given series RC. AT ONE FREQUENCY! (V. important to remember that).
Ah I will remember that thanks! I think I've worked it out... Rs^2 + Xs^2 / Rs = Rp
(Rs being series resistance, and Rp being parallel resistance) which comes to 2.331 kΩ
I also used Rs^2 + Xs^2 / Xs to calculate the Parallel Reactance which came to 861.326Ω
By using 1 / 861.32*2PI*700 I got 264nF.
Therefore C = 264nF & R= 2.331KΩ for the parallel circuit of the same impedance
12K
