Circular arc of charge, integration question
The discussion centers on calculating the electric field from a circular arc of charge, specifically addressing the integration of the x-component of the electric field. The differential electric field is expressed as dE = (λ ds) / (4 π ε₀ r²), where ds represents the differential arc length. To find the x-component, the equation is modified to dEₓ = (λ / (4 π ε₀ r²)) cos(θ) ds, and the relationship ds = r dθ is clarified. This relationship arises from the geometric property of circular arcs, where the arc length relates to the radius and the subtended angle in radians. Understanding this connection is essential for correctly integrating to find the total electric field.
dimensionless
I have a circular arc of wire centered at the point (0,0). It has a radius of r, extends from \theta = -60 to \theta = 60 and also holds a charge q. For the differential electric field I have the following equation:
<br /> dE = \frac{\lambda ds}{4 \pi \epsilon_0 r^2}<br />
Where ds is the length of a differential element of the arc.
To the find the x component of the electric field I this equation:
<br /> dE_{x} = \frac{\lambda}{4 \pi \epsilon_0 r^2} cos(\theta)} ds<br />
To integrate this I have to set ds = r d\theta so that the above equation reads:
<br /> dE_{x} = \frac{\lambda}{4 \pi \epsilon_0 r^2} cos(\theta)} r d\theta<br />
Where does the r come from in the statement ds = r d\theta?
That is just the relation between an arclength and the subtended angle in a circle. Recall that, as long as the angle is given in radians, we have s = r \theta, right? This is true for any arc fo a circle. If you tell me that an arc of a circle subtends {\pi \over 8}radians, for example, and that the circle has a radius of 20 cm, then the length of the arc is simply {5 \pi \over 2} cm.
For an infinitesimal subtended angle d \theta the relation is obviously that the infinitesima arc length is ds = r d \theta.
