Circular motion I HAVE NO IDEA WHAT I AM DOING
The problem involves a ball of mass M attached to a string of length L, moving in a vertical circular motion. The tension in the string at the top is specified to be twice the weight of the ball, and the ball just clears the ground at the bottom. The task includes determining forces, velocities, and time of descent after the string is cut, with expressions required in terms of M, L, and g.
  • Participants discuss the forces acting on the ball at the top of the circle and how to express the net force. There are questions about the appropriate equations to use for determining velocity and time of descent. Some participants express confusion about the distinction between initial velocity and velocity at the top.
Participants are actively engaging with the problem, raising questions about the correct interpretation of the equations and the relationships between different variables. Some guidance has been offered regarding the use of specific equations, but there is no explicit consensus on the approach to take for each part of the problem.
There is a noted lack of clarity regarding the initial velocity versus the velocity at the top of the circle, which may affect the understanding of the problem. Additionally, the assumption that air resistance is negligible is acknowledged.
Toto06
A ball of mass M attached to a string of length L moves in a circle in a vertical plane as shown (picture of circle with a radius drawn L and M as a ball on the circle.) the tension at the top in the string is twice the weight of the ball. At the bottom the ball JUST clears ground Air resistance is negligible. Express your answers in terms of M,L, and g.
a. determine the magnitude and direction of the net force on the ball when it is at the top.
Fn=mg-ma?
b. Determine the initial velocity of the ball at the top.
F=mv^2/r?
c.Determine the time it takes the ball to reach the ground if the string is cut when the ball is at the top of the circle.
d. Just before the string was cut, what was the string tension at the bottom? Assume that the ball has the same velocity at all points around its path.
Sorry I didn't show too much work but that is because i truly don't know where to start. PLEASE HELP
Fn=mg-ma?
At the top of the circle, what are the two forces acting and what direction are they in? The resultant of the two forces give the net force.
F=mv^2/r?
Yes you will need to use mv2/r. When you get the answer for part one, you can use mv2/r to get 'v'.
You'll get 'v' from above. Just use the parabolic equations of motion to find time,t. Hint: When the string is cut, the ball flies off at a tangent to the circle.
Form the equation for the resultant force at the bottom and you will have 'v' from before.
for part b though that formula solves for v I need Vo.
I think part b just wants you to get v
