Clausius-Mossotti Equation and Dielectric Constants of Air
  • Thread starter Thread starter Blastrix91
    Clausius
The discussion centers on the application of the Clausius-Mossotti equation to calculate the polarizability of air, using provided values for molar mass, density, and dielectric constant. The user attempts to derive the polarizability, α, but finds a discrepancy between their calculated value and the one in the textbook. Feedback highlights an error in the molar mass of air and suggests a misapplication of the Clausius-Mossotti equation, particularly regarding the denominator. Additionally, clarification is sought on whether the calculated polarizability pertains to a molecule or an atom. The conversation concludes with the user acknowledging the corrections and expressing gratitude for the assistance.
Blastrix91
http://img809.imageshack.us/img809/5676/unavngivetk.png
Additional table info:
The molarmass ##M_{air}## is ##29 * 10^{-3} g/mol = 29*\frac{10^{-3}}{1000} kg/mol##
The mass density ## \rho_{air} ## is ##1.3 kg/m^{3}##
The dielectric constant ## K_{air}## is 1.00059
My teacher told me to consider the air as 1 molecule.
http://img94.imageshack.us/img94/1667/unavngivet2w.png
Here is my approach:
Basically it is only N we need which is molecules per volume:
N = \frac{Molecules}{V} = \frac{N_a n}{V} = \frac{m}{M_{air}} \frac{N_a}{V} = \frac{\rho_{air}V}{M_{air}} \frac{N_a}{V} = \frac{\rho_{air}N_a}{M_{air}}
\alpha = \frac{3 \varepsilon_0 M_{air}}{\rho_{air}N_a} \frac{K_{air}-1}{K_{air}+1}
Inserting the values:\frac{3(8.854*10^{-12})(29*\frac{10^{-3}}{1000})}{1.3(6.022*10^{23})} * \frac{1.00059 - 1}{1.00059 + 1} = 2.902 * 10^{-43}
The answer in the back of my book says it is supposed to be: ##\alpha = 9.7 * 10^{-41}##
Can any of you guys spot where I did wrong? (The table values were some I got from my teacher and if my approach is right, then he might have wrote them wrong)
A quick Google check on the molar mass of air will show an error in this value.
You used
but the denominator of ##K_{air}+1 ## does not agree with the form of the Claussius-Mossotti equation that you quoted.Also, does your answer for ##\alpha## correspond to a molecule or an atom?
All three things you pointed out gave me the right answer. Thank you ^^
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
