Closest possible points on skew lines
  • Thread starter Thread starter lubricarret
    Lines Points
The discussion focuses on finding the closest points P and Q on two skew lines defined by the parametric equations. The lines are represented as P: x=7-5t, y=-5+11t, z=-3-1t and Q: x=-354-8t, y=-194+12t, z=-73+7t. The solution involves using the cross product of the direction vectors to determine the normal vector and applying projection techniques to find the distance between the lines. The final step requires solving a system of equations derived from the relationship between the points on the lines and the normal vector.
  • Understanding of skew lines and their properties
  • Familiarity with parametric equations of lines
  • Knowledge of vector operations, specifically cross products
  • Proficiency in projection formulas in vector calculus
  • Learn how to derive parametric equations for skew lines
  • Study the properties and applications of the cross product in 3D geometry
  • Explore projection techniques in vector calculus
  • Investigate optimization methods for minimizing distances between geometric entities
Students and professionals in mathematics, physics, or engineering who are dealing with vector calculus, particularly in the context of spatial geometry and optimization problems involving skew lines.
lubricarret
Find points P,Q which are closest possible with P lying on line:
and Q lying on line:
*the line joining P + Q is perpendicular to the two given lines.
Projection formula, cross product...
So, this is the first time I've seen a problem with skew lines, so am a bit confused how to go about this one.
I wrote the equations to be :
X_p = [7,-5,-3] + [-5,11,-1]s
X_q = [-354,-194,-73] + [-8,12,7]t
Therefore, the direction vectors are:
d_p = [-5,11,-1] and
d_q = [-8,12,7]
I took the cross product: [-5,11,-1] x [-8,12,7] to get the normal that is perpendicular to both lines, to be:
[89,43,28]
I figured I would take a point on Line P, and a point on Line Q, to get an arbitrary vector connecting the two lines; I took the points given in the equation:
[7,-5,-3] - [-354,-194,-73] to get v = [361,-189,70]
I then projected this onto the normal, so took:
proj_n_v
Am I correct in doing this? Would this proj_n_v be the distance from P to Q? If it is, what do I do now to get the two points P and Q.
Am I going about this correctly; I've never encountered this type of problem before, but see it in the practice problems on projections...
Thanks so much.
Yes, the projection will give you the distance. To get the actual two points, write W=[89,43,28] (your cross product). Then the difference of the two points must be parallel to W. So write X_p(s)-X_q(t)=u*W. That gives you three equations in three unknowns, s,t and u. Solve them. You could also do this more directly by minimizing (X_p(s)-X_q(t))^2. (Take the two partial derivatives wrt s and t and set them to zero.).
Thanks for the reply Dick!
Ahh k, got it now! )
19K
