4,104 replies · 526K views
Homework Helper
- 3,447
- 3,739
Homework Helper
- 3,447
- 3,739
Mentor
- 37,541
- 14,421
Can be used for entertainment, but also as weapon against the launch pad[/size].
- 20,819
- 28,467
I thought for impact defense!mfb said:Can be used for entertainment, but also as weapon against the launch pad.
- 7,622
- 13,923
- 16,801
That's really difficult to look at. It's so clearly a spiral, even once you've worked out it isn't.Demystifier said:When you use a circular argument, but you are unable to see where exactly your logical error is.
Bikash Kumar Das
- 7
- 2
[emoji16][emoji16]
256bits
- 2,297
The rings are slowly rotating in opposite directions.
- 7,622
- 7,622
This would be in another dictionary, because even most mathematicians see category theory as abstract nonsense.nuuskur said:abstract nonsense = category theory
- 7,622
- 20,819
- 28,467
Perfect! And I finally understood the co- / contravariant usage by physicist, because the proper usage in category theory ...Demystifier said:
I would have changed the classical section a bit:
basic operations = commutative algebra
classical field theory = Galois theory
field = real or complex numbers
mathematical analysis = calculus
measure theory = analysis
I herewith propose this image (1st one) as fb ad for PF!
Keith_McClary
- 752
- 1,507
Keith_McClary
- 752
- 1,507
When the TURBO feature was discontinued, the cases used by the local builders still came with the button and display, so obviously they had to hook up the display, even though the button didn't do anything.jack action said:turbo button! ... After pushing the button and noting no differences, you pushed it again, wondering if it was working.
- 28,467
Just for the greenhorns: these numbers did not represent GHz.Keith_McClary said:When the TURBO feature was discontinued, the cases used by the local builders still came with the button and display, so obviously they had to hook up the display, even though the button didn't do anything.
Btw., do young people still know what a jumper is?
OCR
- 996
- 936
Well, you're real close, but not quite correct... .
The last pickup to leave the parking lot... . "when it's cold outside."
Lol... .
In Montana, a jumper is...DrClaude said:Nah, they just it's something you put on when it's cold outside.
Lol... .
Mentor
- 38,152
- 10,759
And man alive, it does get cold there. I saw the bank thermometer in Lolo, MT one evening showing -39. That's the "banana belt," as they call it around there, so called because it's warmer than, say, Havre, up on the Highline.OCR said:In Montana, a jumper is...
BTW, for our more cosmopolitan friends, -40 F = -40 C, so when it's -39 out, it doesn't matter much which scale you're measuring by ...
- 7,622
Chuck Norris can count real numbers.
Chuck Norris can shave all those and only those who don't shave themselves.
Chuck Norris can prove the Banach-Tarski theorem - by explicit construction.
Chuck Norris can prove his own consistency without being inconsistent.
hyunxu
- 54
- 16
- 2,936
We have a bell button on the gate. We never had an actual bell, but we have a button anyway.Keith_McClary said:When the TURBO feature was discontinued, the cases used by the local builders still came with the button and display, so obviously they had to hook up the display, even though the button didn't do anything.
When somebody coming and there is no button, they tends to get nervous and start shouting inside if we are at home or not.
Since there is a button, they just push it a few times and then calmly go away.
So that button has a significant contribution to the overall calmness of the world.
DennisN
- 10,328
- DennisN
- · Replies 17 ·
- Science Fiction and Fantasy Media
- Replies
- 17
- pivoxa15
- · Replies 36 ·
- General Discussion
- Replies
- 36
