Comparing Gravity on Different Planets Using a Pendulum
  • Thread starter Thread starter brayrbob
    Pendulum Planets
An astronaut measures the period of a 50 cm pendulum on two different planets, recording 2 seconds on planet x and 1.5 seconds on planet y. Calculations show that the gravitational acceleration on planet x is approximately 493.48 cm/s², while planet y has a significantly higher gravity of about 877.30 cm/s². Therefore, planet y has the largest gravity. The values of gravity are confirmed based on the pendulum's oscillation periods. The discussion concludes that the calculated gravity values are accurate for each planet.
brayrbob
Here is my problem that I have partly solved.
An astronaut visits planet x. She takes out a 50 cm pendulum and records a period of oscillation of 2 seconds. Then the astronaut visits planet y, takes out the same pendulum and records a period of oscillation of 1.5 seconds. Which planet has the largest gravity? What is the value of gravity on that planet?
g = 4pi^2(50)/2^2 = 493.4802201 for planet x
g = 4pi^2(50)/1.5^2 = 877.298169 for planet y
Now I'm not sure how to find the value of gravity for planet y.
you've already calculated the gravity "g" for both planets.
(note: to obtain g in mks units, recalulate values using pendulum length of 0.5 meters instead of 50 cm.)
So the gravity for the planets is the vaule of gravity?
planet y has the vaule of gravity of g= 877.29cm/s^2
yes (at the location of the pendulum)
