Complete the statement (relates to the atwood machine)
In the context of the Atwood machine, when the unbalanced force increases while keeping total mass constant, the system's acceleration increases. Conversely, if the total mass that is accelerating increases with a constant unbalanced force, the acceleration decreases. The fundamental equation F = ma applies, indicating that for a constant force, an increase in mass results in decreased acceleration. The discussion emphasizes that in an Atwood machine, maintaining unchanged unbalanced forces necessitates that individual masses also remain constant. Therefore, any alteration in mass directly impacts the system's acceleration dynamics.
~christina~
Completing sentences...
When the unbalanced force increases (total mass remaining constant), the acceleration of the system increases
When the total mass that is accelerating increases (unbalanced force remains constant), the acceleration of the total system decreases
F= ma ?
(this relates to the Atwood machine)
above
Thanks Astronuc :D
This is a terrible question. In an Atwood's Machine, you can not change the total mass, and have the unbalanced forces be unchanged.
Proof:
a = \frac{M-m}{M+m}g
\implies F_1 = Ma = \frac{M-m}{M+m}Mg ~~~~~~~(1)
and ~F_2 = ma = \frac{M-m}{M+m}mg ~~~~~~~~~(2)
Let us change the individual masses, so that M \longrightarrow M'~,~~m \longrightarrow m'. Then again, we can write the equations for the unbalanced forces acting on the two blocks:
\implies F'_1 = M'a = \frac{M'-m'}{M'+m'}M'g ~~~~~(3)
and ~F'_2 = m'a = \frac{M'-m'}{M'+m'}m'g ~~~~~~~(4)
If the unbalanced forces are to remain unchanged, then F'_1=F_1~,~~F'_2=F_2. So that gives us:
\frac{M-m}{M+m}M=\frac{M'-m'}{M'+m'}M'~~~~~~~~~~~~~(5)\frac{M-m}{M+m}m=\frac{M'-m'}{M'+m'}m'~~~~~~~~~~~~~~(6)
Dividing (5) by (6) gives:
\frac{M}{m}=\frac{M'}{m'}~\implies \frac{M}{M}=\frac{m}{m'}
Call the latter ratios \alpha, so that we have M' =M \alpha~, ~~m'=m\alpha.
Making these substitutions in (5) and (6) gives 1=\alpha.
In other words, if the unbalanced forces are to remain unchanged, the individual masses must also be unchanged.
