Complex Numbers- Square root 3i
7 replies · 12K views
JC_003
(1- sqrt 3i) ^3
I am having trouble solving the sqrt 3i part. I think I need to use de moivres theorem but I am unsure. If someone could push me in the right direction that would be a massive help. Thanks.
What's the question exactly? You want to write that complex number in its polar representation or as x+iy? Either way start with writing [itex]1-\sqrt{(3i)}[/itex] in the polar representation. Once you have that it is easy to compute [itex](1-\sqrt{(3i)})^3[/itex].
I think he meant:
[tex]\sqrt[3]{1-i\sqrt{3}}[/tex]
Use De Moivre's theorem to find all the solutions.
The question is:
If z= 5 +4i, write the number z(|z|^2-(1- sqrt3i)^3) in the form a+bi.
I am able to sub everything in but I want to simplify the (1- sqrt3i)^3. The square root has thrown me off.
I take it the i is inside the square root? Try to write it in the form [itex]3i=|z|e^{i\phi}[/itex] then take the square root on both sides.
Is that meant to the theta or phi? Silly question I know. I have in my notes a simalar formula for Eulers formula but that uses theta not phi... Another silly question I know but by changing the sq root 3i into a simple number going to give me the same result as getting the polar representation of the whole (1 - sqrt3i) ^3?
It doesn't matter whether it's called phi, theta or JC_003 it is just a variable which represents the angle between |z| and the positive real axis. You will get the same answer both ways, as it should. However the angle theta is pretty hard to find for [itex]1-\sqrt{3i}[/itex]. I suggest you write [itex]\sqrt{3i}=x+iy[/itex] first and then continue from there.
If this is an exercise from a text, I'd be very carefull about whether the question concerns
[tex](\sqrt{3})i[/tex]​
or
[tex]\sqrt{(3i)}[/tex]​
Huge difference.
The question is not clear enough for me to help effectively, but I suspect -8 shows up somewhere.
--Elucidus
