Confused on Voltage Calculations: Using Nodal Analysis to Find Input to Amp
The discussion focuses on using nodal analysis to determine the input voltage to an amplifier in a circuit with a voltage divider. The user initially calculated a voltage of 10V through the auxiliary circuit but struggled with the role of a 0.5A current. Through nodal analysis, they found that the voltage at the first node was 1/3 of the starting voltage and 1/6 at the second node, concluding that the amplifier, with its infinite impedance, would see the 1/6 value. The user determined that a gain of 6 is necessary to restore the output voltage to 10V.
  • Nodal analysis in electrical engineering
  • Understanding of voltage dividers
  • Concept of amplifier impedance
  • Basic circuit analysis techniques
  • Study advanced nodal analysis techniques for complex circuits
  • Learn about voltage divider circuits and their applications
  • Explore amplifier configurations and their impedance characteristics
  • Investigate the impact of current sources on circuit behavior
Electrical engineering students, circuit designers, and anyone involved in amplifier design and analysis will benefit from this discussion.
righteous818
I have attachted the question as a picture:
my first attempt i calculated the voltage through the auxillary circuit to be 10V but i am confused of where the 0.5 A plays in this part, then i used nodal analysis to find the voltage input to the amplifier but up to that point i am confused of how to proceed, am i working the question through the right steps or am i missing something
I think the voltage entering the circuit has a maximum of 10V from the voltage divider.
When I carry out the nodal analysis I get 1/3 of the starting voltage at the first node, and 1/6 of the starting voltage at the 2nd node ... and since the amplifier has "infinite impedance" it will see this 1/6 value.
Thus the gain must be 6 in order to recover the output of the voltage divider.
Clearly the 0.5A current is routed not through the amplifier, but down and around the return loop (implied ground). So the 0.5A is not part of the solution, but the source of the problem!
what i did is used the division ratio an the current and the high voltage to find 2 resistors that will give that division ratio but remember if u put the auxillary circuit over the resistor which gives that 10V it will change the resistance thus i found the the new voltage across it then found the voltage at the node going intot the amplifier, so remember what we want is 10 v across that resistor so the amplifier has to amplfiier it back to 10v, that's what i did
