Conservation of Angular Momentum of particle
A 2.80 kg particle collides inelastically with a 4.00 kg particle, leading to a calculation of the angular momentum with respect to the origin. The confusion arises from the use of different coordinate systems (ij and xy), but it is clarified that they are related. The angular momentum is calculated using the formula L = m(r x v), leading to a final result of 6.02 kg*m^2/s in the k direction. The discussion emphasizes the importance of understanding the relationship between the coordinate systems for accurate calculations. The solution is confirmed and appreciated by participants in the discussion.
Versaiteis
A 2.80 kg particle that is moving horizontally over a floor with velocity (-3.00 m/s) \widehat{j}undergoes a completely inelastic collision with a 4.00 kg particle that is moving horizontally over the floor with velocity (4.55 m/s)\widehat{i}. The collision occurs at xy coordinates (-0.50 m, -0.10 m). After the collision, what is the angular momentum of the stuck-together particles with respect to the origin?
answer = 6.02\widehat{k} kg*m^2/s
L = m( r x v )
I can't seem to understand exactly what I'm supposed to do, what keeps throwing me off is the two different coordinate systems, ij and xy. No matter what combinations of vectors I use, nothing comes close, so I guess what I'm looking for is a place to start.
Versaiteis said:
L = m( r x v )
Keep in mind that the angular momentum vector is always perpendicular to the plane of \vec{r} \text{ and } \vec{v}.
The i, j, and k axes are all perpendicular to each other, of course. \hat i is the unit vector along the x-axis in the direction of + x. \hat j is the unit vector along the y-axis in the direction of +y. The \hat k direction is perpendicular to both the i and j unit vectors.
AM
Oh I see, the two systems are directly related so I can simply say
L = L_{1} + L_{2}
L_{1} = 2.8 * (-0.5 * -3.00)
L_{2} = 4.0 * ( 0 - (-0.1 * 4.55))
Sure enough
L = 6.02\widehat{k} kg*m^2/s
Thank you for your help Andrew
L = L_{1} + L_{2}
Sure enough
No problemo.
AM
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
