Consider the lines & find an equation of a plane [Cal III]
  • Thread starter Thread starter BoonBoon
    Lines Plane
The discussion revolves around finding the intersection of two lines in three-dimensional space and determining the equation of the plane that contains these lines. The subject area pertains to vector equations and geometric interpretations in calculus.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the intersection point of the lines and the nature of the resulting equation, with some expressing confusion about interpreting the equation of a plane versus a line.
Some participants have provided guidance on the interpretation of the equation derived, clarifying that it represents a plane rather than a line. There is an acknowledgment of differing understandings regarding the implications of coefficients in the equation.
There is mention of a lack of clarity in the original poster's understanding of the implications of having a zero coefficient for z in the equation, which may have contributed to their confusion.
BoonBoon
Consider the Lines Below:
r
= <2, 3, 0> + t<3, -3, 1>
r = <5, 0, 1> + s<-3, 3, 0>
A.) Find the point at which the given lines intersect.
B.) Find an equation of the plane that contains these lines.
[/B]
The vector equation of a line is given by r = r0 - tv
The equation of a plane is given by N . (r - r0)
I worked everything to the best of my ability but I ended up getting an equation of a line as opposed to the equation of a plane... Did I do something wrong? Here is a picture of my work:
r
[/B]
I don't see anything wrong with your work. The two lines intersect at (5, 0, 1) (I checked), and the equation of the plane is indeed x + y = 5. In three dimensions this is a plane.
Thank you so much. I think I figured out the error in my way of thinking. For some reason I was thinking of my answer as looking like a cube in R3. But since x + y = 5 is a line in R2, I could just scale the Z value infinitely in either direction in R3, as long as I'm restricted to that line. Thus, I would have a plane. Interesting. Thanks so much for your response!
You say " I ended up getting an equation of a line" but that is not true. A line cannot be written as a single equation in 3 dimensions. What you have is a plane in which the coefficient of z happens to be 0. That simply means that the plane is parallel to the z-axis. You can think of it as the line defined by x+ y= 5 in the xy-plane extended parallel to the z-axis.
Yes, you are absolutely right. Having 0 as the coefficient of Z is what scared me. My professor hadn't covered what that meant very well, so I was confused. Thank you very much for your input.
  • · Replies 23 ·
