How Long Until a Pulsar Stops Rotating?
The discussion centers on calculating how long it will take for a pulsar, specifically in the Crab nebula, to stop rotating given its current rotation period of 0.160 seconds and an increase in this period at a rate of 0.00000506 seconds per year. The user attempted to use the equation for angular motion but miscalculated the time, arriving at an implausibly short duration of about 1 year instead of the expected thousands. The conversation highlights the need to correctly identify the initial and final angular speeds when applying the formula to determine the total time until the pulsar ceases rotation. Clarification is sought on the appropriate angular speeds to use in the calculation. Accurate calculations are essential for understanding pulsar dynamics and their long-term behavior.
shadowice
A pulsar is a rapidly rotating neutron star that emits radio pulses with precise synchronization, there being one such pulse for each rotation of the star. The period T of rotation is found by measuring the time between pulses. At present, the pulsar in the central region of the Crab nebula has a period of rotation of T = 0.16000000 s, and this is observed to be increasing at the rate of 0.00000506 s/y.
If its angular acceleration is constant, in how many years will the pulsar stop rotating?
already found
angular acel to be -3.935x10^-11 rad/s^2
wf = 39.269
wi = 39.2699
Im stumped as to how to find this, i had initially tried to use wf = wi + angular accel*t thinking that the t i solved for would be the value i wanted.
i did 39.269 = 39.2699+ -3.935x10^-11t
that gave me 31559593.39 seconds then i did conversions to turn s into yrs which was that /60 s /60 min/24 hr/365d = 1.0007 yrs which is way to small it should be thousands of years shouldn't it.
Hi shadowice,
already found
wf = 39.269
wi = 39.2699
I have not checked all your numbers here, but your two angular speeds you have are the angular speed at the initial point (wi) and one year later (wf). So when you calculated the time, you got back the original time of one year.
So instead, if we want to calculate the time when the pulsar stops, what angular speeds would be used in the equation?
