Control forces of hydraulic piston pump
The discussion focuses on designing a foot pedal mechanism to actuate two hydraulic piston pumps, with a torque requirement exceeding 100 In-lbs. The user expresses concern about the unexpectedly high effort needed to operate the foot pedal due to the torque required for full stroke and the return spring mechanism. They seek advice on reducing the effort needed to actuate the pumps. Clarification is requested regarding the type of piston pumps, the fluid being pumped, and the specific application. The conversation highlights the challenges of mechanical design in hydraulic systems.
Ken.Li
We are designing a foot pedal mechanism to actuate two hydraulic pistion pumps.
But the torque to actuate a pump is more than 50In-lbs at full stroke. In addition, a
spring is used to make the control shaft of a pump return to its neutral position.
Totally the torque to actuate a pump is over 100In-lbs.
So the effort applied on the foot pedal to actuate two pumps is much more I expected.
Can someone tell me any ways to reduce the effort on the foot pedal?
Many thanks.
Many thanks.
Please describe the piston pumps, fluid to be pumped, and application. The way I read your post, you want to rotate the pumps that are pumping a fliud by pushing down on a pedal? Like a bicycle pedal?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
