Trying to measure the change in resistance of an electromagnet
In summary, the speaker is trying to measure the change in resistance of an electromagnet when a coin is placed near it. They are encountering problems with the voltage across the bridge circuit, which is charging to -15V even when the direction of the capacitor is changed. The speaker is using a low-voltage AC source and is trying to use a bridge rectifier and storage capacitor to convert the input sine wave to a DC component with ripple. They have tried reversing the arms of the bridge circuit but it has not helped. They also mention using a peak detector to store the peak voltage and have it stored by a computer program, but note that constructing a DC peak detector is easier than an AC peak detector. The expert suggests using an opamp
propergomper
hi, as part of a project me and my friends are undertaking we are trying to measure the change in resistance of an electromagnet when a coin is placed near near the electromagnet. i have been trying to use a bridge rectifier to convert the system to DC but i have been encountering a few problems,
the voltage across the bridge circuit seems to be charging to -15V and does the same even if i change the direction of the capacitor in the bridge rectifier
if anyone could shed any light onto why this is happening or knows how to help then it would be greatly appreciated
many thanks
It sounds like you need to change the direction of your diodes. The capacitor is only a storage device to even out ripples in the current.
What is your AC source? If it is 120Vrms or 230Vrms AC mains power, please be *very* careful working with it. Hopefully you are not messing with wall power.
If it is from a low-voltage AC source, then yes, you can use a bridge rectifier and storage capacitor to convert the input sine wave to a DC component with ripple. The bridge rectifier is described on this wikipedia.org page, for example:
http://en.wikipedia.org/wiki/Bridge_rectifier
Keep in mind that if you output smoothing capacitor is polar, you must be sure to get the polarity of the bridge output and the polarity of the capacitor matching. If you connect a polar electrolytic capacitor backwards, you will generally blow up the capacitor (bad).
Give us a circuit diagram or at least a verbal description of what you've got and what you're trying to measure. Sounds like you're just looking at your power supply.
heres what I've got so far,
ive got one connection of a signal generator (100KHz) connected to a coil (electromagnet) which is connected in series with a 1 ohm resistor which is connected back to the signal generator. I've been measuring the voltage change across the resistor when different metals were placed in close proximity to the electromagnet. then I've connected either side of the resistor to a bridge rectifier circuit as described in the wikipedia site, I've also tried reversing two diagonally oppposite arms of the bridge circuit as described on another website but to no avail.
thanks
Whew, I'm relieved to hear you're not using AC mains power.
Just use an oscilloscope or a DVM with 100kHz frequency response to measure the AC voltage across the resistor. There's no need to try to rectify it -- that will introduce errors of its own (the diode voltage drops, for example). Can you just use an AC measurement?
i could but i was needing to use a peak detector to store the peak voltage and have that value stored by a computer program
and i know this sounds lazy but the DC peak detector circuit looked much easier to construct on a protoboard than a AC peak detector
thanks for your help
Okay, but make your peak detector with an opamp to get rid of the diode voltage loss. Do you know how to make an opamp-based peak detector? wikipedia.org may show one, or google definitely would. Or it should just be in your opamp textbook. 100kHz is easily within the range of an opamp-based peak detector.
100 kHz? You say, "electromagnet;" which usually means inductance enough that your entire signal is across the resistor. You're going to want to operate at a lower frequency or wind ten or twenty turns around a cardboard or plastic coil form to get a low enough inductance to see anything.
Edit: Oh, wow, did I ever get that exactly sideways. 'Tany rate, large inductance means the big voltage drop is across the inductor. If you're getting the signal generator's rms across the resistor, you need to check ground and common for the sg, and for whatever you're using to read the bridge output.
1. How do you measure the change in resistance of an electromagnet?
To measure the change in resistance of an electromagnet, you will need a multimeter. Set the multimeter to measure resistance and connect the probes to the ends of the electromagnet's coil. Record the initial resistance. Then, apply a varying amount of current to the electromagnet and record the new resistance. The change in resistance can be calculated by subtracting the initial resistance from the new resistance.
2. Why is it important to measure the change in resistance of an electromagnet?
Measuring the change in resistance of an electromagnet is important because it can provide information about the strength and performance of the electromagnet. Changes in resistance can also indicate potential problems with the electromagnet, such as a short circuit or overheating.
3. What factors can affect the change in resistance of an electromagnet?
The change in resistance of an electromagnet can be affected by various factors, such as the amount of current passing through the coil, the number of turns in the coil, the material of the core, and the temperature of the coil. Any change in these factors can result in a change in the resistance of the electromagnet.
4. How does the change in resistance affect the strength of an electromagnet?
The change in resistance can directly affect the strength of an electromagnet. As the resistance increases, the current passing through the coil decreases, resulting in a weaker magnetic field. On the other hand, a decrease in resistance can lead to a stronger magnetic field. Therefore, measuring the change in resistance can help determine the optimal conditions for the electromagnet to achieve maximum strength.
5. What are some potential applications for measuring the change in resistance of an electromagnet?
Measuring the change in resistance of an electromagnet can be useful in various applications, such as in the design and testing of electronic devices, electric motors, and generators. It can also be helpful in monitoring the performance and health of industrial electromagnets, such as those used in magnetic separation or lifting heavy objects. Additionally, the change in resistance can be used to control the strength of an electromagnet in real-time for applications such as magnetic levitation or magnetic braking.
  • Electrical Engineering
