Coriolis Effect - Vertical Shot, solution through integration?
The discussion focuses on calculating the distance between the starting and landing points of a vertically shot projectile, considering the Coriolis effect at different latitudes. The poster provides a detailed mathematical approach using tensors and matrices, while also expressing a desire for feedback on their alternative solution. They calculate the time of flight and derive the necessary formulas for distance based on Earth's curvature and rotation. The poster notes a lack of responses, indicating a need for clarification on whether their post is appropriately placed in the forum. Overall, the thread seeks validation of the proposed solution to a physics problem involving the Coriolis effect.
Malor
Hi, it's my first time on these forum, so I hope that I made this post correctly.
I have an example solution to this problem using tensors and matrices ^^ but I wanted to solve the problem in a different way and would like some feedback on whether or not this solution is correct.
A gun shoots a projectile vertically into the air with an exit velocity of vvert=60ms-1 (assuming the nozzle is at sea level). Calculate the distance Δs, between the starting point and landing point of the projectile. Do this for the latitudes 0° and 51°. (neglect cascading effects)2. The attempt at a solution
Getting the time t for the whole process is a no-brainer:
v(t) = 0 = vvert-gt , g = const. => t1 = 6.1s => ttotal = 12.2s
Now to calculate Δs:
We assume that the Earth is an ideal globe, with a radius r = 6370000km. Basic geometry tells us that the distance from the axis of rotation is
R = sqrt(h(2r-h)) => R = sqrt(r²-r²sin²(α)) , α...latitude => R = r*cos(α)
The circumference of r(t) is the gives us the orbital velocity vB = const.:
r(t) = r + ∫v(t)dt
2∏r(0)/d = vB , d...day
vB is constant => ω can not be constant:
ω(t) = vB1/vB21 = u1/u21 = r/r(t)*ω1 (R1/R2 = r1/r2)
Angular acceleration: w'(t) = - (r*v(t))/(r+∫v(t)dt)² * ω1
Δω = ω1 ∫ -(r*v(t))/(r+∫v(t)dt)² dt
Δs = Δω*R*t = r*cos(α)*t*ω1 ∫ -(r*v(t))/(r+∫v(t)dt)² dt
Thank you for your troubles.
150 views, no replies... did I put this in the wrong section? ;)
bumb
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
