Coulomb's Law - Line of Charge
The discussion centers on solving a problem involving Coulomb's Law for a line of charge with a uniform density of 8 µC/m along the z-axis, specifically between z=0 and z=5 cm. The electric field (E) is to be calculated at the point (0, 10 cm, 0). The correct approach involves integrating the expression for E, which is derived from the line charge distribution and incorporates the vector components of the electric field. The final expression for E is split into two integrals, addressing the y and z components separately, confirming that the answer should indeed have contributions in both directions.
  • Understanding of Coulomb's Law and electric fields
  • Familiarity with vector calculus and integration techniques
  • Knowledge of line charge distributions and their properties
  • Proficiency in using LaTeX for mathematical expressions
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about vector calculus applications in electromagnetism
  • Explore the use of LaTeX for formatting complex mathematical equations
  • Investigate the behavior of electric fields in three-dimensional space
Students and educators in physics, particularly those focusing on electromagnetism, as well as anyone seeking to deepen their understanding of electric fields generated by line charges.
WesleyPipes
Well, I am raging over my homework and not even going to turn it in because I can't complete enough of it. I really just need to figure this problem out so I don't feel as bad about it. I know this shouldn't be as hard as I am making it, but all examples only have answers containing a single-direction vector.
A line of charge with uniform density Pl=8(uC/m) exists in air along the z-axis between z=0 and z=5 cm. Find E at (0,10cm,0).
R = y(.1)-z(z) --- really Vector(R) = Yhat(.1)-Zhat(z)
Mag(R) = sqrt(.01+z^2)
Rhat' = Vector(R)/Mag(R)
Line Distribution:
E=(1/(4*Pi*Epsilon))*Integral(z=0 to z=0.05)[Rhat'*(Pl)/Mag(R)^2]dL
Sorry if the equations are ridiculously hard to read.
Each time I try this, I get an answer in the +y direction when I feel like the answer vector should be in the (-z,+y) direction.
Thanks guys.
In your final expression for E, dL is dz. Here's the Latex version of that expression incorporating all of your other results.
[tex]\vec{E}=\frac{1}{4\pi\epsilon_0}\,\int_{0}^{.05}\frac{\Pi\hat{R}}{R^2}\,dz[/tex]
[tex]=\frac{1}{4\pi\epsilon_0}\,\int_{0}^{.05}\frac{\Pi(0.1\hat{y}-z\hat{z})}{R^3}\,dz[/tex][tex]=\frac{1}{4\pi\epsilon_0}\,\int_{0}^{.05}\frac{\Pi(0.1\hat{y}-z\hat{z})}{(0.01+z^2)^{3/2}}\,dz[/tex]​
This splits into the difference of two integrals.
[tex]\vec{E}=\frac{\Pi}{4\pi\epsilon_0}\left(0.1\hat{y}\,\int_{0}^{.05}\frac{1}{(0.01+z^2)^{3/2}}\,dz\ -\hat{z}\,\int_{0}^{.05}\frac{z}{(0.01+z^2)^{3/2}}\,dz\right)[/tex]
which gives the two components you want.
Thanks, knew I was missing something simple. I feel a lot better now haha.
