Coulomb's Law, Rearranging Equation.
  • Thread starter Thread starter Syncert
    Coulomb's law Law
To find the distance between two electrostatic point charges of +60 microCoulombs and +50 microCoulombs exerting a force of 175 N, the equation Fe = Kc (q1*q2/r^2) is used. Rearranging the equation leads to r^2 = Kc*q1*q2/Fe. Taking the square root of both sides gives the final formula R = √(Kc*q1*q2/Fe). This approach confirms that solving for r involves straightforward algebraic manipulation. The discussion highlights the simplicity of the rearrangement process in applying Coulomb's Law.
Syncert
Two electrostatic point charges of +60 microCoulombs and +50 microCoulombs exert a repulsive force on each other of 175 N. What is the distance between the two charges?
Fe=Kc (q1*q2/r^2)
I know I need to rearrange the equation, to get r^2 over to the other side of the equation. Do I have to square root both sides to figure this out?
Fe=Kc (q1*q2/r^2)
*r^2 * r^2
Fe*r^2 = Kc (q1*q2)
/Fe /Fe
R^2=Kc*q1*q2/Fe
Welcome to PF!
Hi Syncert! Welcome to PF! :smile:
(try using the X2 and X2 icons just above the Reply box :wink:)
Fe=Kc (q1*q2/r^2)
*r^2 * r^2
Fe*r^2 = Kc (q1*q2)
/Fe /Fe
R^2=Kc*q1*q2/Fe
Yes, that's fine …
R = √(Kc*q1*q2/Fe) :smile:
Wow it was really that simple...thank you. =]
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
