Calculating Electron Flow in a Copper Wire
  • Thread starter Thread starter sdkl84
    Current Wire
An electric current of 6 A flows through a 5 mm diameter copper wire that is 10 m long. The calculation for the average number of electrons flowing through a cross-section of the wire per second involves using the relationship I=Q/t. The result is approximately 3.744E19 electrons per second. The diameter and length of the wire were found to be unnecessary for this specific calculation. The discussion concludes with a resolution of the problem, affirming the correctness of the solution.
sdkl84
An electric current of 6 A flows through a 5 mm diameter copper wire with a length of 10 m.
What is the average number of electrons that flow through a cross section of the wire per second?
I=Q/t or I=dQ/dt Maybe, I am not sure
1 Coulomb = 6.24e18
6*6.24e18
3.744E19 e/s
nvm i figured it out thanks anyway!
Weird as the diameter and length are unnecessary. But thumbs up for solving it!
