Cyclist cycling in a perfect circle - find radius
  • Thread starter Thread starter Woody11
    Circle Radius
A cyclist weighing 78 kilograms is cycling in a perfect circle at a velocity of 12 m/sec while leaning at a 30-degree angle. To find the radius of the circle, the centripetal force formula F=mv²/r is applied, where the forces acting on the cyclist are balanced due to equilibrium. By setting the centripetal force equal to the gravitational force component, the radius can be calculated as r = v²/(g*tan(30)). After substituting the known values, the radius is determined to be approximately 1.47 meters. Understanding the relationship between the forces and drawing a diagram can aid in solving similar physics problems.
Woody11
I am doing a Biomechanics course and it is just like physics. I don't have a large back ground when it comes to physics. So I need some help. I am having a problem with a question on an assignment. This is the question:
A 78 kilogram cyclist is cycling in a perfect circle, with a velocity of 12m/sec. If The cyclist is leaning at 30 degrees and is in a perfect equilibrum, what is the radius of teh circle they are cycling around?
It doesn't seem to be a hard question, but I have been trying to figure this out for about 5 hours now and nothing is hitting me on how to do it. I know it has to deal with centripetal force and I think I should be using the formula F=mv2/r at some point. But I have no idea what the first step is. I hope someone can help me get started, remember I have very little background when it comes to physics it has been a while since I have done it.
Thanks,
Woody :frown:
Because rider is in equilibrium at 30 deg to the VERTICAL, the road surface applies Force "F" (shown in drawing below) whose components are sufficient to balance rider's gravitational force (m*g) and provide centripetal force (m*v2/r) required for uniform circular motion. Force "F" components are shown in the drawing. Thus, for equilibrium:
{Centripetal Force} = {"F" Horizontal Component}
::: ⇒ m*v2/r = m*g*tan(30)
::: ⇒ r = v2/{g*tan(30)}
::: ⇒ r = (12 m/sec)2/{(9.81 m/sec2)*tan(30)}
::: ⇒ r = (25.4 meters)
Code:
                       |       / [B]F[/B]
                       |  30  /
                   m*g |    / m*g/cos(30)
                       |/________>
                        m*g*tan(30)
            Road Surface Force Components On Rider
Hello Woody,
First of all, don't worry if you don't have a strong background in physics. Biomechanics and physics go hand in hand, and it's perfectly normal to need some help with understanding concepts and solving problems.
For this question, you are correct in thinking that you will need to use the formula F=mv^2/r. This is known as the centripetal force formula and is used to calculate the force required to keep an object moving in a circular motion.
The first step is to identify the known values in the problem. In this case, we know the mass of the cyclist (m=78kg), the velocity (v=12m/sec), and the angle at which the cyclist is leaning (30 degrees). We also know that the cyclist is in perfect equilibrium, meaning that the forces acting on them are balanced.
Next, we need to draw a free body diagram to visualize the forces acting on the cyclist. In this case, there are two forces acting on the cyclist: the centripetal force (F) and the force of gravity (mg). The force of gravity is acting downwards, while the centripetal force is acting towards the center of the circle.
Now, we can use the formula F=mv^2/r to solve for the radius. Since the cyclist is in equilibrium, the centripetal force must be equal to the force of gravity. So, we can set up the following equation:
F=mg=mv^2/r
We can rearrange this equation to solve for r:
r=mv^2/mg
Plugging in the known values, we get:
r=(78kg)(12m/sec)^2/(78kg)(9.8m/s^2)
Simplifying, we get:
r=14.4m/s^2/9.8m/s^2
r=1.47m
So, the radius of the circle that the cyclist is cycling around is approximately 1.47 meters.
I hope this helps you understand the problem and how to approach it. Remember, it's always helpful to draw diagrams and identify known values before solving a physics problem. Good luck with your assignment!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
