Cylinder Optimization for a Minimum?
dandaman
Question: Cost of producing cylindrical can determined by materials used for wall and end pieces. If end pieces are 3 times as expensive per cm2 as the wall, find dimensions (to nearest millimeter) to make a can at minimal cost with volume of 600 cm3.
Relevant equations: a) V=600cm3=[pi]r2h
b) surface area = 2[pi]r2 + [pi]rh
The miraculous attempt:
a) solve h in terms of [pi]r2: 600=[pi]r2h ; 600/[pi]r2=h
b) find surface area equation using h: SA=2[pi]r2 + 2[pi]r(600/[pi]r2 ; SA=2[pi]r2 + 2(600/r) ; SA=2[pi]r2 + 1200/r
c) first derivative: SA'= 4[pi]r - (600/r2) = 0
I am regrettably hitting a brick wall on what should happen next. Additional information is that I think the cost looks something like: 2[pi]r2 = (2[pi]rh)(3), with the multiplication by 3 being the fact that the round end pieces are three times as expensive.
Any and all further help would be greatly appreciated.
Dan
The constraint equation is as you have it
V = pi*r^2*h = 600
The cost function is the surface area, weighted by the production cost factors:
C = 2*pi*r*h + 3*2*pi*r^2
where the first term is the cost of producing the side wall and the second term is the cost of producing the two ends, with the factor 3 included to reflect the higher manufacturing cost for the ends.
Your previous approach was to solve the constraint for h, so let us do this again:
h = V/(pi*r^2)
and then substitute into the cost function
C = 2*pi*r*V/(pi*r^2) + 3*2*pi*r^2
= 2*V/r + 6*pi*r^2
Now differentiate wrt r ...
dC/dr = -2*V/r^2+12*pi*r
set the derivative equal to zero...
0 = -2*V/r^2 + 12*pi*r
=V - 6*pi*r^3
r^3 = V/(6*pi)
and so forth...
(all assuming that I did not make any mistakes!)
Thanks a million! The math seems to check out on paper as well, with a radius of 7.3 cm and a height of 3.6 cm. (Volume would end up being 602.7 cm3.)
Dan
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
