Damped Oscillator Conceptual Problem and Differential Equation Solution
2 replies · 5K views · last reply
ggilvar99
Hey guys I'm new to the forum and having a little trouble with this conceptual problem.
1. A block of mass m is connected to a spring, the other end of which is fixed. There is also a viscous damping mechanism. The following observations have been made of this system:
i) If the block is pushed horizontally with a force equal to mg, the static compression of the spring is equal to h
ii) The viscous resistive force is equal to mg as the block moves with a speed u.
a) Write the differential equation governing horizontal oscillations of the mass in terms of m, g, h and u.
b) for the particular case of u = 3√gh, what is the angular frequency of the damped oscillations?
2. Homework Equations :
mx'' + λx' + kx = 0
3. The Attempt at a Solution :
F = mg = -kh (x = h)
F = mg = -λu for x' = u
At this point I'm somewhat lost and not sure what they're looking for. If the viscous force = mg at velocity u, how can you translate that into a differential equation that covers all velocities of the mass? Any help would be greatly appreciated
Can you obtain express ##k## and ##\lambda## from the conditions given?
Oh, you're saying to set k = -(mg)/h and lambda = -(mg)/u and plug that into the diffeq? I don't know why that never occurred to me, thanks a lot for the suggestion!
