DC Motor Speed Increases Under Load - Modeling w/ Simulink
Modeling a DC motor in Simulink shows unexpected behavior, with speed increasing from 180 rads/s under no-load to 290 rads/s under load, despite longer acceleration times. The user, with a mechanical background, questions why speed increases under load, expecting a decrease instead. Key concepts discussed include that torque is proportional to current and back EMF is related to RPM, indicating that applied voltage influences unloaded speed. The conversation suggests a potential issue with the user's model that needs review. Understanding these principles is crucial for accurate motor modeling.
Nick Goodson
Hi, I am modelling a DC motor using Simulink.
Under no-load conditions, I get a max speed of 180 rads/s, but under load, the speed goes up to 290 rad/s, although takes longer to reach max speed, acceleration decreases.
I have a mechanical background so don't know much about motors, but would expect that, under load, the speed would reduce?
Any ideas?
Many thanks.
Assuming it is a simple DC motor with brushes.
Torque is proportional to current. Back EMF is proportional to RPM.
Applied voltage – back EMF appears across the rotor resistance and so decides current.
Unloaded speed will be proportional to applied voltage.
Increasing load will slow the motor until current rises to give torque required.
You have a problem with your model.
Likes jim hardy and cnh1995
Ok, thanks Baluncore. I need to review what's happening.
Cheers
Nick
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
