Mass of C1 to C2 Ratio: Find the Answer
  • Thread starter Thread starter student 1
    Density Mass
The discussion focuses on calculating the mass ratio of two cylinders, C1 and C2, based on their densities and dimensions. Cylinder C1 has a density D1 and is three times taller than cylinder C2, which has a density of 2D1 and a radius four times larger than C1's. The volumes of both cylinders are derived using the formula for the volume of a cylinder, leading to expressions for their respective masses. The calculated mass ratio of C1 to C2 is proposed to be 3/32. Participants confirm the method used is correct, with one expressing initial uncertainty about their calculations.
student 1
A cylinder C1 has density D1, and C2 has density 2D1. The height of C1 is 3 times as large as height of C2, and the radius of C2 is 4 times as large as the radius of C1. Find the ratio of the mass of C1 to C2.
Density=Mass/Volume
Volume of Cylinder=(pi) R^2(L)
Volume of C1=(pi)R^2(3H)
Volume of C2=(pi)(4R)^2(H)
Mass of 1= D1(pi)(R)^2(3H)
Mass of 2=2D1(pi)(4R)^2(H)
SO mass of C1 to C2 would be {D1(pi)(R)^2(3H)}/{2D1(pi)(4R)^2(H)}
Answer I came up with was 3/32. Is this right?
Hi student_1,
Your method looks right to me. Is there something about it that doesn't seem right to you?
I got an answer totally different the first time just seeing if i was doing it right. I believe I had the wrong method at first though.
Right.
