Density of electrons in a metal (electricity)
To find the density of free electrons in a metallic wire with a diameter of 4.12 mm and a current of 8.00 A, the relevant equation is I = nqv(drift)a. The user rearranged this equation to solve for n, which represents the number of charge carriers per unit volume, yielding a value of approximately 6.95 x 10^28 m^-3. The discussion emphasizes that this value of n is indeed the density of free electrons in the metal. Dimensional analysis confirms that n has the correct dimensions for density, validating the calculation. The final answer for the density of free electrons is thus 6.95 x 10^28 m^-3.
Talz1994
A metallic wire has a diameter of 4.12mm. When the current in the wire is 8.00 A, the drift velocity is 5.40 10^-5 m/s
What is the density of free electrons in the metal?
Express your answer numerically in m^-3 to two significant figures.
I=nqv(drift)a, where I is current, a is cross sectional area, v(drift) is the drift velocity, n is the number of charged particles per unit volume (i.e., the concentration of charged particles), and q is the magnitude of the charge on a charge carrier.
This really confused me, but here's the equation that was given as a hint for the question when asked:
I=nqv(drift)a :where I is current, a is cross sectional area, v(drift) is the drift velocity, n is the number of charged particles per unit volume (i.e., the concentration of charged particles), and q is the magnitude of the charge on a charge carrier.
this is another hint given to question when asked:
Recall the definition of current as the net charge flowing through a given cross-sectional area per unit time. If you express the net charge flowing through the area in terms of the concentration of the charge carriers per unit volume, you will find that the current depends on the concentration and charge of the charged particles, as well as on the magnitude of their drift velocity. Recall that in metals the charge carriers are free electrons.
I really don't understand this question, can somebody please walk me through it? step by step,
i rearranged the equation
I/Avq=n
n=6.945314735*10^28
what do i do next, how am i supposed to find density from number of electrons :@
You already found the number of free electrons pr unit volume, which i think is the density.
seriously i have? how?
What is the dimensions of 'n' in the formula you used. Can you evalute its dimensions using dimensional analysis?
