Can You Derive Equations Using UAM Principles?
  • Thread starter Thread starter jensgt
    deriving
The discussion revolves around deriving equations 5-1 and 5-2 using Uniformly Accelerated Motion (UAM) principles. A participant expresses uncertainty about how to begin, mentioning attempts with range and height equations without success. Others suggest focusing on standard constant acceleration equations for both x and y directions, emphasizing the importance of using the correct variables. They encourage sharing progress and remind to avoid confusing notation. The conversation highlights the collaborative effort to understand and apply UAM concepts in physics.
jensgt
Can you come up with (i.e. derive) equations 5-1 and 5-2 on your own using UAM equations? Try it
This is the equation I need to end up at...
R=Vox/g(Voy+(Voy^+2gh)^1/2
I am not really sure where to start. I was trying to use the equations for range and height but it does not seem to be getting me anywhere. This is my first physics course.
welcome to pf!
hi jensgt! welcome to pf! :smile:
(try using the X2 button just above the Reply box :wink:)
don't try to memorise (or use) the range or height equations :wink:, go back to the standard constant acceleration equations, for the x and y directions (separately)
they'll use the same t …
show us what you get :smile:
The equations I know are
Vx = Vox + Axt
X = Xo + Voxt + 1/2axt^2
X-Xo = [(Vox + Vx)/2]t
Vx^2 = Vox^2 +2ax(X-Xo)
I am just confused as to where to start. I derived the other one he asked us about this one has me stuck.
hi jensgt! :smile:
(just got up :zzz:)
use x = xo + Vxot + 1/2axt2
and y = yo + Vyot + 1/2ayt2
(obviously, ax = 0) …
(btw, never use "x" for times, it's too confusing … use "*" instead, or nothing at all! :wink:)
