Describing the circle of a uniform rod hit at one end
When a ball strikes a uniform rod, it imparts both linear and angular momentum, causing the rod to move backward and rotate. The torque generated during the impact is calculated as the force multiplied by the distance from the rod's center of mass to the point of impact. The angular momentum of the rod post-collision can be expressed as the product of this arm distance and the linear momentum. The center of the circle described by the rod's motion is located at its center of mass, which dictates the radius of the circular path. Understanding these dynamics is crucial for accurately calculating the radius and center of the circle formed by the rod's rotation.
schaafde
I have a uniform rod laying on a table. A ball comes in and hits the rod making it move backwards but also rotating. Assuming that we are in a frictionless environment, how do describe the circle made by the rod?
Circle made by rod?
The ball will transfer linear and angular momentum to the rod. While we don't know the exact time-profile of the impact force, we know that torque = force * arm at any given moment. Arm, in this case, is the distance from rod's center of mass to the point of impact. That means that after collision rod's angular momentum = arm * linear momentum. Using moment of inertia for rod you should easily be able to find the ratio between rod's linear and angular velocities from that.
yes if the ball hit the bat and the bat rotated around in a circular motion. How would i describe that circle?
A circle only has one parameter - radius. You're not making a whole lot of sense.
I understand that but the radius should be longer than the length of the bat because the bat is not pinned at one end. Therefore the center of the circle isn't at the end of the bat. I guess I am asking where is the center of the circle and how would I calculate that new radius.
Center of the circle is at the center of mass. The center of mass of a body, when no external force is applied, can only move in a straight line. Everything else rotates around the center of mass.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
