Design theory problem with clearance fit
The discussion revolves around a homework problem related to clearance fit and the need for additional data to solve it effectively. Participants highlight that the question's wording is unclear, complicating the solution process. It is suggested that there are four potential answers based on the combinations of diameter tolerances. To approach the problem, users recommend plotting the thermal expansion equations for steel and copper using tools like Desmos. Ultimately, the conversation emphasizes the importance of clear problem statements and the use of graphical methods for finding solutions.
Marvin94
I think it will make use of tables...
Can someone tell me the solution step by step of this problem? Help me please :(
Thanks in advance..
I'd like to help but the wording of the question is poor and additional data needed to solve problem would have to be looked up .
There are in any case potentially four different answers depending on the four combinations possible for high/low on the two diameter tolerances .
Likes berkeman
use desmos (or similar) and plot the equations for thermal expansion
plot two lines
the expansion of steel
the expansion of copper
You will then be able to read off the temperatures easily
or you could put the relevant dimensions into the equation to begin with - whatever you are happy with
Thanks for all the answers :)
10K
