Determine compositions of functions
  • Thread starter Thread starter Cyborg31
    Functions
Cyborg31
Let h: Z -> Z be defined as follows:
h(n) = 0 if n is even and 1 if n is odd
Determine h^2, h^3, and h^500
If n is even, h(n) = 0 then h(h(n)) = h(0) = 0
If n is odd, h(n) = 1 then h(h(n)) = h(1) = 1
If n is even h(n) = 0 then h(h(h(n))) = h(h(0)) -> h(0) = 0
If n is odd h(n) = 1 then h(h(h(n))) = h(h(1)) -> h(1) = 1
Then for h^500, if n is even then the result is 0 and n is odd then the result is 1.
Can someone tell if that's correct?
Thanks.
Hi Cyborg31!
Yes, that's right! :smile:
Why, were you worried that it wasn't? :wink:
(Of course, you could also write the result: h^2 = h, h^500 = h. :smile:)
Seem correct, though unnecesarily long.
Already after
you can conclude h^2 = h and therefore h^k = h for all k >= 1.
Forum signature: www.lingouist.blogspot.com[/URL]
1. Let f, g: R -> R where f(x) = ax + b and g(x) = x^2 - x + 1. If (g o f)(x) = 9x^2 - 9x + 3, determine the values of a and b.
So I got g(ax + b) = (ax + b)^2 - (ax + b) + 1
(a^2*x^2 + 2(a * b)x + b^2) - (ax + b) + 1 = 9x^2 - 9x + 3
(9x^2 + 2(3 * b)x + b^2) - (3x + b) + 1
(9x^2 + 2(3 * 2)x + 4) - (3x + 2) + 1
9x^2 + 12x + 4 - 3x - 2 + 1
9x^2 + 9x + 3
I know a = 3 and b = 2 but I'm not sure if those steps are correct. I don't think I've shown a way as to how I got the 2 for b. I got the a cause of the coefficient of the square. Anyone know if those steps are correct?
2. Let f, g: R -> R where f(x) = ax + b and g(x) = cx + d for any x element of R where a, b, c, and d are real constants. What relationships must be satisfied by the four constants for the equality: (f o g)(x) = (g o f)(x) for all x element of R?
(f o g)(x) = f(g(x)) = f(cx + d) = a(cx + d) + b
(g o f)(x) = g(f(x)) = g(ax + b) = c(ax + b) + d
a(cx + d) + b = c(ax + b) + d
I got a = c and b = d so that the coefficient and the constant matches so that they're equal. But I think I'm missing some steps of work.
Thanks.
Actually nm, I figured it out.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
