Determine energy levels of a electron in a hydrogen atom
To determine the principal quantum numbers n1 and n2 for an electron transition in a hydrogen atom emitting light at 658.1 nm, the Rydberg formula is essential. The energy of the emitted photon can be calculated using E = hc/λ, yielding a value of approximately 3.022 x 10^-19 J. The relationship between the energy levels can be expressed as E = -hcR/n^2, leading to two equations with two unknowns. By utilizing trial and error with positive integer values for n1 and n2, and considering the Balmer series where n' is typically 2, the correct transition levels can be identified. Understanding the energy differences and the visible wavelength range is crucial for solving the problem effectively.
Jonas Persson
When an electron in a hydrogen atom makes a transiton between two levels with prinicipal quantum numbers n1 and n2, light is emitted with wavelength of 658.1 nm. If we assume that the energy levels of the atom are in agreement with the Bohr model, what are n1 and n2?
I tried to calculate:
E = hc/λ = 3.022 * 10-19
which is the Energy for the wavelength.
E = -hcR/n^2
n^2 = -hcR/E
n^2 = -R/λ
which result in negative value(?)
Then I tried with
λ = (n1^2 - n2^2)/R
but then I always get two unknowns, and can't really come any further than that. Maybe I am looking in the wrong way or missing some theory.
Jonas Persson said:
Assignment
Attempt
E = -hcR/n^2
n^2 = -hcR/E
n^2 = -R/λ
Then I tried with
λ = (n1^2 - n2^2)/R
First, get straight what the story is of how the photon is produced:
  1. The electron originally has energy E_1 (which can be written in terms of the quantum number n_1)
  2. It emits a photon of energy E (which you calculate above).
  3. Afterward, the electron has energy E_2 (which can be written in terms of n_2)
So by conservation of energy, what is the relationship between E_1, E_2 and E?
You're right, you will have two unknowns, n_1 and n_2. But they are positive integers. So you can just try various values for n_1 and n_2 to see which combination works.
Likes lekh2003
Jonas Persson said:
Assignment
Jonas Persson said:
Attempt
E = -hcR/n^2
n^2 = -hcR/E
n^2 = -R/λ
Then I tried with
λ = (n1^2 - n2^2)/R
You use wrong formula. The wavelength is attributed to two levels, according to the Rydberg formula.
25b1437b6d7203b25493f3a6b399aaf2c591e352
where Z is the atomic number (1 for Hydrogen atom) and n , n' are the energy levels, n'<n. R is the Rydberg constant. (RH = 0.010972 nm-1)
I tried adjacent orbits - no luck!
Don't expect the equation is exactly valid for any pair of n and n', but the emitted light is visible, what can be n'?
Once n is picked, n' is easy to determine - but how to pick n other than by trial and error?
You know the wavelength ranges of the emission lines of Hydrogen atom. They are well separated according to the lower level. Emission in the visible range corresponds to the Balmer series, with n'=2 as lower level.
Likes rude man
stevendaryl said:
You're right, you will have two unknowns, n1n1n_1 and n2n2n_2. But they are positive integers. So you can just try various values for n1n1n_1 and n2n2n_2 to see which combination works.
I think this solution is the simplest. If you are learning about electron transitions, then you must surely have learned about the different series. Either you can check your textbook (or online) for the energy values of the different transitions from different "n" states.
The value you calculate, E, is simply the difference between energy states. If you still don't understand what the value of E really is, take a look at this link:
http://www.kentchemistry.com/links/AtomicStructure/waveenergy.htm
Re search: something like this perhaps. Spot the 'candidate' !
## \begin{array}{|c|c|c|c|c|c|}
\hline & m & 1 & 2 & 3 & 4 & 5 \\
\hline n \\
\hline 1 & & & 0.750 & 0.889 & 0.938 & 0.960\\
\hline 2 & & & & 0.139 & 0.188 & 0.210\\
\hline 3 & & & & &0.049 & 0.071\\
\hline 4 & & & & & & 0.023\\
\hline
\end{array}##
Likes lekh2003
